Connection Issue with GoDaddy Hosting
I have successfully installed PowerCMS on numerous sites hosted with our reseller account which is NOT Go Daddy. I have a new customer with Go Daddy hosting and I cannot seem to connect to the database correctly with dreamweaver.
When I tried to connect to the database in dreamweaver I get this error. “Your PHP server doesn’t have the MySQL module loaded or you can’t use the mysql_(p)connect functions.” The database and DSN are installed on the server and I can admininster the database using PHP My Admin.
This is the help information I found on the Go Daddy site: The following is a list of database connection strings to use with various MySQL data providers. Cut and paste the connection string to use within your application. For connection strings that require a password, update the password field to the designated password for the database.
ODBC 3.51:
DRIVER={MySQL ODBC 3.51 Driver}; SERVER=mainconnection.db.2191195.hostedresource.com; PORT=3306; DATABASE=mainconnection; USER=mainconnection; PASSWORD='your password'; OPTION=0;
OLE DB, OleDbConnection (.NET):
Provider=MySQLProv; Data Source=mainconnection.db.2191195.hostedresource.com; Initial Catalog=mainconnection; User ID=mainconnection; Password='your password';
Connector/Net 1.0 (.NET):
Server=mainconnection.db.2191195.hostedresource.com; Port=3306; Database=mainconnection; Uid=mainconnection; Pwd='your password';
I have attached my connection file. Thank You!
