With Google Map no WADA dynamic data is displayed
Thread began 9/28/2011 12:52 pm by Dennis | Last modified 9/30/2011 4:55 pm by Dennis | 838 views | 2 replies |
Dennis
When I add a Pro Map for Google to my Detail page created with WADA Wizard, using the same recordset, my dynamic data doesn't display anymore (just blank table cells). However the map is showing the correct location for the search record.
I had it working at one time, then I tried changing the map to get multiple pins to display. Now no matter what I do, including removing all Pro Map stuff on the page and adding it from scratch, I cannot have it on the page and have the dynamic data display.
Dennis
member_LookUp_Detail.zip
the map has probably left the recordset result at the last record.
look for the following code on your page:
<?php if ($totalRows_WADAmember_accounts 0) { // Show if recordset not empty ?>
and change it to:
mysql_data_seek
($WADAmember_accounts0);
$row_WADAmember_accounts mysql_fetch_assoc($WADAmember_accounts);
this will reset the recordset to the first record.
Dennis
That did the trick, thanks Jason.
Dennis
