Access corresponding column for select
Thread began 9/28/2011 10:12 am by rogersds267040 | Last modified 9/30/2011 2:36 pm by Jason Byrnes | 765 views | 5 replies |
rogersds267040
I have a drop that sets the value=id and name to be display in the dropdown. See attachment app.zip.
There's also another column called email which am trying to send an email to email address according to the id that's select in the drop. It keeps sending to the same address.
Any assistance will be appreciated.
app.zip
srappointment_Insert.zip
edit the WADAemail recordset.
instead of filtering the id column on the "email" querystring variable, filter the id column on the "email" form variable.
Next edit the Universal Email behavior. Instead of using the WADADynListkfm_users recordset for the to address, use the WADAemail recordset
rogersds267040
Thank you, it work on the srappointment_Insert.php but doesn't on the srappoinment_Update.php page.
I tried the following but email is not being sent when I select a name from the dropdown.
I tried the following:
$_POST["appasignto"]
$row_WADAsrappointment["appasignto"]
srappointment_Update.zip
the update record behavior is set to redirect to the srappointment_Detail.php page.
this redirect happens before UE can try to send the email.
remove the redirect from the update record behavior.
rogersds267040
Thank you but after removing the redirect option the still didn't work. See attachment.
In addition, the insert page works fine and there's a redirect option.
Please note that there are to set of email on that same page and email 1 works fine. Just email 2 that doesn't work on that update page but works fine on the insert page.
you have set UE to use the appasignto form element as the to address.
instead, you should use the email column of the WADAemail recordset
