HTML Editor Image Upload Problem! PLEASE Help!
Thread began 9/26/2011 6:14 am by g292818 | Last modified 9/27/2011 12:12 am by g292818 | 1987 views | 6 replies |
g292818
Hi, I am having a problem with uploading image through HTML Editor, any help would be greatly appreciated. PLEASE!!!!
When I click on the image upload icon the small pop up layer opens and then it just stays blank indefinitely. Please see the screen shot
in the webassist/kfm/index.php page
find the following line:
<script type="text/javascript" src="j/all.php/can-minify"></script>
and change it to:
<script type="text/javascript" src="j/all.php"></script>
g292818
can't find the folder
Hi Jason, thanks once again for your response - I have checked and don't seem to have the file you speak of; In fact I do not have a "webassist" folder.
WHere is it supposed to be?
I have an HTMLEditor folder, which in turn has other subfolders, etc..
Where is this "webassist/kfm/index.php" supposed to be?
this indicates that you have an earlier version of HTML Editor than the currant 3.0.1 version
make the code change to the HTMLEditor/editor/plugins/kfm/index.php page instead.
g292818
the code
Hi Jason, I had a look and did not quite find the line you mentioned - though I did see one very much like the one you said I should change it to - already in the existing code:
Here:
<script type="text/javascript" src="j/mootools.v1.11/mootools.v1.11.js"></script>
<script type="text/javascript" src="j/jquery/all.php"></script>
and here:
These already existed as you see them in the code - without me doing anything yet.
I have attached the entire code as a txt file:
index.txt
g292818
Hi Jason
Hi Jason, just wanted to let you know I have not heard from or received any update from Support
