Direct if Username exists using IP and date
Thread began 9/25/2011 10:58 pm by ijk76319396 | Last modified 9/26/2011 4:04 pm by Jason Byrnes | 798 views | 5 replies |
ijk76319396
I want to restrict usernames based on IP address and the date. Basically I want the code below to be entered following $loginUsername =
This is the code I want to be there I just don't know how to write it in the redirect if username exists context...
<?php echo((isset($_SERVER["REMOTE_ADDR"]))?$_SERVER["REMOTE_ADDR"]:"") ?>_<?php echo date("Ymd")?>
This is the entire script...
// *** Redirect if username exists
$MM_flag="MM_insert";
if (isset($_POST[$MM_flag])) {
$MM_dupKeyRedirect=$_POST['website'];
$loginUsername = NEED TO KNOW WHAT TO PUT HERE???
$LoginRS__query = sprintf("SELECT voterIP FROM points WHERE voterIP=%s", GetSQLValueString($loginUsername, "text"));
mysql_select_db($database_con2com, $con2com);
$LoginRS=mysql_query($LoginRS__query, $con2com) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
//if there is a row in the database, the username was found - can not add the requested username
if($loginFoundUser){
$MM_qsChar = "?";
//append the username to the redirect page
if (substr_count($MM_dupKeyRedirect,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername;
header ("Location: $MM_dupKeyRedirect");
exit;
this line:
should be something similar to this:
$loginUsername = "".((isset($_SERVER["REMOTE_ADDR"]))?$_SERVER["REMOTE_ADDR"]:"") ."_".date("Ymd")."";
ijk76319396
That works and it goes into the database correctly but the redirect feature doesn't work allowing for duplicate entries and no redirection. I don't know if it is because the insert record is based upon the "before page load" or what the issue is. I have attached the page file, hopefully you can see what the problem is.
member_profile_IN.zip
to troubleshoot, change line 17:
echo("dupe check = ".$LoginRS__query."br/>");
and 51:
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
die("Insert = ".$WA_Sql);
report back the sql statements this writs to the screen
ijk76319396
The screen shows up and reads: Insert=
