Email never works
Thread began 9/24/2011 5:33 pm by rogersds267040 | Last modified 9/27/2011 11:22 am by rogersds267040 | 1421 views | 4 replies |
rogersds267040
Email never works
I'm trying a basic email setup and it's not working. From the time I bought UE 4, that never work. I have the correct smtp server and port. I tried using a basic php email script and it works fine.
Please see attachment with files.
email.zip
srInsert.zip
on your srInsert.php page, there is an insert record behavior at lines 224 - 254, this is set to redirect to the servicereq_Detail.php, this redirect happens directly after the record is inserted, and before the email code at lines 291 - 378 can be executed.
you need to remove the redirect from the insert behavior in orer to allow the email behavior code to execute.
rogersds267040
Email never works
The changes didn't work. Please see attachment.
email.zip
srInsert.zip
the file you sent to me is named srInsert.php
you have the forms action set to post to another page, servicereq_Insert.php:
<form action="servicereq_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
All form processing must occur on the forms action page
none of the behaviors on this page will ever trigger on form submit since the form submits to another page.
either change the forms action to be blank so it will post to itself:
<form action="" method="post" name="WADAInsertForm" id="WADAInsertForm">
or add the behaviors that will precess the form to the servicereq_Insert.php page.
rogersds267040
Email never works
Thank you, that work.
