Is this where I post this?
Thread began 9/23/2011 3:25 pm by mailtoherb335493 | Last modified 9/26/2011 11:31 am by mailtoherb335493 | 1903 views | 5 replies |
mailtoherb335493
I have had the solution pack for some time now, and finally downloaded the files and just uploaded them directly to my hosting server to view them, ad there are errors?...
see here: contact_styled.php
so not sure what to do, I can fix the output code but it should just work, at least that's the idea.
The error means that the php server is not properly configured to manage session variables.
it is most likely an issue with the session.save_path setting in the php.ini file.
you should contact your host to have them correct the problem.
mailtoherb335493
I called GoDaddy, and they do not support this type of scripting. Is there a statement I can add to my php5.ini file to fix this?
I can paste in the code?...
mailtoherb335493
current php5.ini contents
post_max_size = 192M;
upload_max_filesize = 192M;
upload_tmp_dir = /tmp;
For this reason, GoDaddy is a host I never recommend.
This is a server configuring issue, not a scripting issue. Since it is their server, I would expect them to be able to correct the configuration issue rather than force you to do it yourself.
add the following line to your php5.ini file:
session.save_path = /tmp;
mailtoherb335493
Awesome
Hey, Thank You so much! - That worked...reaming godaddy now, since I have other issues that are likely as easy to fix.
Ha! you know what...I just checked and that fixed a whole host of wordpress issues I had (I can hear you guys laughing now lol) I had numerous plugins that add features disabled on mockups because they had similar error messages.
One godaddy support guys said to remove the <session_start> or whatever from the code because the 'new' versions of php don't need it.
Anyway thanks again, guys like me buy your stuff and use other frameworks or plugins because we don't know this stuff. Just the front-end part. We, or at least I, hate to get the treatment like "the computer guy" on saturday night live where he says "MOOOOOVE"
see here: 858401/
