Using Powerstore 4.5 and PowerCMS 2x Together
Thread began 9/22/2011 12:51 pm by rsawyer341759 | Last modified 9/27/2011 2:24 pm by rsawyer341759 | 1090 views | 2 replies |
I have an installation in test where I have used both Powerstore 4.5 and PowerCMS. The main site is handled by PCMS, and I link to the store via a link within the site. I have altered the home and contact links in PStore to go back to the main site. If I register and login in to Powerstore as a REGULAR customer, when I go back to the main site, I am in EDIT mode.
This is obviously not good, because anyone who registers at the store will have access to the main site in edit mode. I created a php script that logs users out of the store, and out of a PowerCMS login, then links back to the main site. However, if I am logged in to the store, and I happen to hit a new browser tab of the main site, it is in edit mode.
I have discovered that Powerstore and PowerCMS use the same Session ID, which is why PowerCMS thinks it's in edit mode, and why my fix works. However, I am going to need a permanent fix that would keep regular users out of edit on a PowerCMS site if they log in Powerstore and pull up the store in another browser tab.
Dani Chankhour
The only common session between PCMS and PS is the UserGroupID.
The fix to this would be not to set the UserGroupID when logging in to PS.
You can not set the UserGroupID by modifying the following lines of code from the users_login.php page in PowerStore:
"sessionColumns" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."UserEmailVerified".$WA_Auth_Separator."UserEmail".$WA_Auth_Separator."UserGroupID"),
"sessionNames" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."UserEmailVerified".$WA_Auth_Separator."UserEmail".$WA_Auth_Separator."UserGroupID"),
and change them to:
"sessionColumns" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."UserEmailVerified".$WA_Auth_Separator."UserEmail"),
"sessionNames" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."UserEmailVerified".$WA_Auth_Separator."UserEmail"),
Thanks, Dani - the fix works!
