Warning message, gallery not working
Thread began 9/22/2011 7:26 am by tkendrickmail32213 | Last modified 9/22/2011 10:24 am by Jason Byrnes | 831 views | 1 replies |
tkendrickmail32213
I get the below message after installing. Also, nothing works:
Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead in /vservers/c34600-h217924/htdocs/gallery/admin_gallery/images/installed.png on line 2 Warning: strtotime(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead in /vservers/c34600-h217924/htdocs/gallery/admin_gallery/images/installed.png on line 2 Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead in /vservers/c34600-h217924/htdocs/gallery/admin_gallery/images/installed.png on line 2
this error means that the date.timezone is not set in the servers php.ini file:
datetime.configuration.php#ini.date.timezone
you will need to contact the host to have them correct the issue
