DA Sort crashes CS5
Thread began 9/21/2011 1:55 pm by doug.lemesurier305760 | Last modified 9/25/2011 8:34 am by doug.lemesurier305760 | 1237 views | 3 replies |
DA Sort crashes CS5
When I go to add the Server Behavior, sort, the Web Assist Window comes up as normal but after I configure and hit OK, it shuts down DW CS5.
I have removed the WinFileCache.dat with no luck.
any ideas?
Cheers
Doug
iansheldon422428
Hi Doug,
I have had this problem on two different machines, one CS5 and one CS5.5
The CS5 issue is still a problem, but on the CS5.5 machine I uninstalled a DMXZone Extension I had and the WA Sort behaviour then worked!
Go figure! :-)
Have you tried uninstalling and reinstalling the Data Assist extension? Are you running the latest version?
Cheers
Ian
Please send a screen shot of the Dreamweaver Extension manager showing the installed extensions and version numbers in a zip archive, it is most likely a problem with conflicting extensions.
DA Sort crashes CS5
Oddly enough, I removed the Pallet Picker extension ad it worked. I read in another post that the extension was not compatible with CS5.
Cheers!
Doug
