Source Not Working
Hi im trying to use the Source Btn but it dont seam to work all time it's just seams to work as and when it wont to ??
Daniel
Daniel
Can you provide more details please.
When it "doesnt work" what _does_ it do?
What version of Power CMS Are you using?
What Browser are you using?
Power cms 2.1.1
Internet Ex 64bit
You can click the source file and the colour turns blue it opens so you can see the source but when you click in it to edit it nothing happens
This is an issue with the CKEditor in IE 9, try using another browser, or setting IE 9 to use the IE8 browsing engine through the IE developer tools.
to access the developer tools, use the F12 key. In the developer tools, where it says Browser Mode: IE9 change that to IE8
