PowerCMS version number
I am using PowerCMS 2 but am unable to determine which version I installed on the website. How can I obtain the version number?
I'm not sure I understand your question, are you trying to determine if it is version 1 or 2 on the server?
the main difference between version 1 or 2 is the folder structure. In version 1, the admin folder is named "admin" in version 2 it is named "admin_cms" version 1 will have a folder named "HTMLEditor" and the KFM plugin will be under that folder, in version two the kfm files will be at "webassist/kfm"
