How do I retain form content on a failed validation
Thread began 9/19/2011 5:37 am by mrs | Last modified 4/10/2012 10:08 am by Jason Byrnes | 1050 views | 3 replies |
mrs
I have tried to do the 'Validation Show If' on my form page, and it works OK, but when I test it with an incorrect code to make sure it does show the failed validation message, all of the other form content disappears because the page is basically refreshed.
So, if I do use the Validation Show If on the form page, how do I get the form to retain the user entered content? Currently, I have a simple form, but if I use this on a complex form, I can see users getting fed up and moving off to another site, which is not good for business!
At the moment, I have removed the Validation and I redirect to a simple HTML page where I state the captcha code was entered incorrectly and they need to click here to do a history back -1. By doing this, I am able to retain the user entered content, but it's not particularly user friendly.
Thanks.
Use the validated entries collection to set the initial value of the form element:
select the form element, in the property inspector, click the lightning bolt next to initial value, expand the validated entries group and select the corresponding binding.
charles164095
Please explain "validated entries collection" if you would please. Thanks
Open the bindings panel. On a page that has server validation applied to it, there will be a binding collection named Validated Entries. This collection will contain a binding for each form element, when validation fails, the validated entries bindings will save the data for each form element that passed validation to be used to repopulate the form.
