Editor in CSS Sculptor
Thread began 9/19/2011 1:14 am by theo.twisk429002 | Last modified 9/20/2011 1:10 pm by Jason Byrnes | 1681 views | 3 replies |
theo.twisk429002
I want to edit a page that I created/inserted with CSS Sculptor. But I do not see an option in CSS Sculptor to edit the page that is still open in Dreamweaver (as in CSS Menu writer where I can edit the Design etc. for a Menu that I previously inserted). When I use CSS Sculptor and make changes to the preset I saved it inserts a new page. Is making changes to the preset and inserting a new page the only possibility or is there an edit option somewhere in CSS sculptor?
Yes, Editing the preset and saving the new page is the only posibility is CSS Sculptor.
CSS Sculptor is a Layout Creation utility. It will create a new page from the layout you create, it does not offer the ability to edit and existing page.
theo.t429002
follow up question regarding CSS Design Suite
Regarding CSS Design Suite: can only the menu and the colors be edited for an existing page/template?
In Menu writer, you can edit a menu the was created using Menu Writer, if it was created using another method, you will not be able to edit it.
using Theme it, you can edit the colors and images of a CSS Layout.
