Index Page
Please assist in how I can correct the footer so that it displays properly in both fireworks and in ie
index.php
ie the footer is not positioning correctly
Thank you
Gloria
index.php
Thank you
Gloria
in the webassist/themes/SilkPlantsCanada2/css/default_styles.css file, change:
#contentWrapper {
overflow: visible;
#contentWrapper {
overflow: hidden;
Thank you that worked...now having issues with the gallery viewing correctly in ie but not in firefox page.php?Custom%20Pages=5
Using Fire Fox 4, IE7, IE8 and IE 9, I do not see any difference when viewing the page you have linked to. I am not able to reproduce the problem.
okay...
here is what i get...on ie explorer
index.php Featured Product and Most Popular needs to have the pricing and view more adjusted?(where)
products_results.php?Search=1&ProductCategoryID[]=1
needs to have pricing and internet pricing adjusted (where)you will notice that there are product 3 on first row and 1st product on second row that does not belong..these can be corrected. however, 2nd page the page layout is malformed and items 1&2 in row 3 do not belong as well as row 4 item 3. However, if you look at the data base under products they show that they should be in the right categories which is not the one that they are currently in...this happens pretty much on every page and every category as well as still having pictures not able to view
WOW this is turning into a messss....
HELP
THANK YOU!!!
I will advise on firefox when i get this one working
still awaiting a response. Thank you in advance.
what theme did you start with when creating the custom theme that is applied t your store?
looking in the webassist/themes/SilkPlantsCanada2/css/default_styles.css and webassist/themes/SilkPlantsCanada2/css/default_home.css files, there are a lot of styles with padding and margin settings that do not exist in the default theme files:
webassist/themes/default/css/default_styles.css and webassist/themes/default/css/default_home.css
I think these extra passing and margins are causing the display problems you are experiencing.
for the items showing on the results page in the wrong category, add this info to the ticket for your admin settings issue and we will look into it along with the admin settings.
Thank you....that seemed to clean things up!!!
but still showing snag on both ie and firefox
cart.php
product id, more details as well as footer is out...
thank you...I do not want to mess up my css's
muchly appreciative.
Do not know if this css realated but theses categories
pricing looks okay in ie but not in firefox....DA!
products_results.php?pageNum_WADAProducts=1&totalRows_WADAProducts=17&Search=1&ProductCategoryID[]=1
products_results.php?pageNum_WADAProducts=1&totalRows_WADAProducts=21&Search=1&ProductCategoryID[]=10 this has missing items in rows? or plus image issues
products_results.php?pageNum_WADAProducts=2&totalRows_WADAProducts=21&Search=1&ProductCategoryID[]=10 messed up rows???
products_results.php?pageNum_WADAProducts=1&totalRows_WADAProducts=21&Search=1&ProductCategoryID[]=9
Thank you
