Big Question mark
Thread began 9/15/2011 11:57 am by peacehawk | Last modified 9/15/2011 1:18 pm by Jason Byrnes | 834 views | 2 replies |
peacehawk
Big Question mark
I've inserted a captcha in a page and when I go to Live view there is a question mark where the capchta should be. It's true in live view and Remote. I've made sure the dependent files are loaded to the testing server and remote. What Gives?
peacehawk
Big Question
Is there a way to make adjustment or modify once the capctha is loaded onto a page
Most likely you do not have the GD Library enabled on your testing server see the Enable the GD Library setting on your testing server" tutorial on the learning resources page:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
after capthcha has been applied to the page, click the captcha place holder image, this will trigger an edit button in the properties inspector, click the edit button to modify the captcha settings.
