How:vertical menu level 1 drop directly down
please see side bar menu: info.html
Question:
how do I make the level 1 items drop directly down 90 degrees at the same time pushing the main level items below it down.
Question:
i don't think cssmw has this feature.
however if you want to do this, take a look at
ddaccordionmenu.htm
for some ideas, it is quite straightforward to implement
