Displaying developers notes
Thread began 9/12/2011 2:43 pm by wbrooks199805 | Last modified 9/14/2011 1:25 pm by wbrooks199805 | 825 views | 4 replies |
wbrooks199805
Does the page have to be in a specific directory in order to display the developers notes?
For example this code below.
<?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Holistic Healing Programs', 'Content', false, '30');
No the page does not have to be in a specific directory, but you will also need to add an require once reference to the webassist/cms/addtosite.php page, for example:
<?php require_once("webassist/cms/addtosite.php"); ?>
this is a document relative path, so will need to be adjusted based on the where in the site you add this code in relation to the webassist directory.
wbrooks199805
followed thread
Not working and I followed the thread to addtosite.php
//set config
$abs_file = str_replace('\\', '/', dirname(realpath(__FILE__)));
$abs_prefix = substr($abs_file, 0, strrpos($abs_file, '/') + 1);
$included = strtolower(realpath(__FILE__)) != strtolower(realpath($_SERVER['SCRIPT_FILENAME']));
include_once($abs_prefix . 'Connections/PowerStoreConnection.php');
include_once($abs_prefix . 'WA_CMS/WA_CMS.php');
I don't see a folder on the server: WA_CMS/WA_CMS.php
Try using this code instead:
<?php require_once('Connections/PowerStoreConnection.php'); ?>
require_once("webassist/cms/cms.php"); ?>
echo WA_getCMSContent($database_PowerStoreConnection$PowerStoreConnection'Holistic Healing Programs''Content'false'30');
wbrooks199805
That worked!
Thanks Jason! :)
