Several Questions RE: Checkout Wizard
Thread began 9/10/2011 10:19 pm by johna1964 | Last modified 9/12/2011 11:51 am by Jason Byrnes | 441 views | 1 replies |
johna1964
Hi!
I deleted the previous checkout pages as you directed, reran the wizard. The wizard ran flawlessly, but I am encountering the following issues after upload:
1) Shipping USPS: All I need to do is set up an account with them? Use the UserID is the same as User Name when you set up the account, then replace the WA_eCart_USPS_PHP.php with the support fix?
, but it continues to maintain the fixed rate.
I could not find any other instruction, even on the USPS site...some direction would be good....actually any information would be good....
I believe I need some help here. Please let me know if you need additional info.
The other issues are not present at this time...
Thank you again!
johna1964
the cehckout wizard will not remove any fixed rate charges you have applied before.
You will need to edit the eCart object go to the shipping tab and delete any of the previously defined shipping rules that will no longer apply.
see the following page for details on signing up for an account with USPS:
signup_usps.php
