Database Assistance - multi-entry fields.
Thread began 9/10/2011 9:40 am by thebeards427087 | Last modified 9/12/2011 7:08 am by Jason Byrnes | 805 views | 1 replies |
thebeards427087
Hi.
This is not directly a Data Assist question as such, but as Im using Data Assist, I thought somebody may be able to point me in the right direction.
I am making a recipe website for a friend.
My friend will be inserting the criteria into the database from the back end.
One of the tables in my database is called ingredients.
I have the ingredients field set to textarea.
The problem is, instead of displaying the ingredients as a list, the textaraea just runs the text inline. How do I go about getting the ingredients into list form?
I could make several ingredient fields, but this will cause display problems if there are say 30 ingredients or just 2. I have seen on some websites where an extra box 'appears' if you fill one box, but doesnt if the box is empty. This seems like the perfect method for my problem, but I have absolutely no idea how to implement it.
Does anyone here know? Any advice appreciated.
Scorpio66
With a text area, when you use the enter key while entering data into it, the enter key gets inserted to the database as "\r\n" (this is a system character for Carriage return, New Line).
On the page where you display the ingredients, use the nl2br() function, this will convert "\r\n" to a <br /> tag:
<?php echo(nl2br($row_recordsetName["ColumnName"])); ?>
