Pages Won't Load
My site was working but now only loads the header with no errors. Can you please take a look?
index.php
index.php
looks like there is a php error occuring.
Add the following code at line 1 of the index.php file to turn on error reporting:
error_reporting(E_ALL);
I put this in and get no errors. I think it's something to do with PowerGallery. The home page and galleries don't work. The other pages do.
After updating the PHP version to 5.0, my home page looks very wierd.
index.php
it looks like the gallery that you added to the site message section is an empty gallery which is causing the gallery javascript to set the width of the outerwrapper element to 2px.
try removing the gallery, that should correct the problem, you may need to recreate the gallery, then apply it again.
