Cannoy login to admin
Thread began 8/31/2011 1:28 pm by alistair316863 | Last modified 9/01/2011 6:39 am by Jason Byrnes | 1842 views | 5 replies |
alistair316863
Hi I have just uploaded a new site which I created locally and have now uploaded the site to the customers hosting via ftp, I had to send them a dump from phpmyadmin for the sql file everything is ok and the site is live and pulling the text etc from the database.
But when I go to admin_cms/ I get a blank screen with no login I can send you the ftp details if required please can you sort this for me asap as the client is getting mad with me thanks Alistair
this means that there is a php error occurring, but error reporting is turned off.
add the following code at line 1 of the admin_gallery/index.php page to turn error reporting on:
error_reporting
(E_ALL);
once we know the error, we can troubleshoot the cause.
alistair316863
Hi Jason I have done that can you have a look it is now reporting error, ne I added the line to the admin_cms index.php as i think that is what you meant. But whilst we are on about the gallery is there a way i can change the path for the images as i first created the gallery locally? But obviously first things first error at admin_cms/ is:
Warning: require_once(../webassist/framework/library.php) [function.require-once]: failed to open stream: No such file or directory in /content/HostingPlus/g/l/glazeritewindows.co.uk/web/admin_cms/index.php on line 6
Fatal error: require_once() [function.require]: Failed opening required '../webassist/framework/library.php' (include_path='.:/usr/local/fphp5/lib/php') in /content/HostingPlus/g/l/glazeritewindows.co.uk/web/admin_cms/index.php on line 6
the error is saying that this file has not been uploaded to the server:
library.php
make sure to upload the webassist directory.
alistair316863
Thanks Jason sorted now, Is there anything I can do about the gallery in this site without having to re-do it
what is the issue you are having with the gallery? Please provide more details on the nature of the problem.
