DD in search page: why don't work?
I try to use dd in search page but nothing! no work (but in other pages work fine). Why?
wrong forum: the right one is dynamic dropdown! sorry
please send a link where i can see the issue in the web browser.
ok, so it is the results page that is not working correctly, please end a zipped copy of the results page:
annuncio_Results.php
yes, but the search working, only dropdown menu from Categoria to Sottocategoria not
add the following code to the results page after the <body> tag, this will help me to see what is going on:
<php echo("SQL: ".$query_limit_WADAannuncio."<br />"); ?>
ob but there are not record in WADAannuncio
i understand that, the code i provided will output the SQL being run to the page, If i can see the SQL that is being executed, It may help me understand what the problem is.
It looks like you have not added the code correctly to the results page it is only outputting ") ?>
if it is properly added to the results page, it will show the SQL being executed.
