Galleries
Thread began 8/29/2011 11:05 am by biz295654 | Last modified 8/29/2011 11:36 am by biz295654 | 938 views | 2 replies |
biz295654WebAssist
Galleries
Where would the settings be so that the ribbon gallery in powerstore can be set to only 2 across, as many down as needed? Or is there another powergallery setting I can employ. I know in powergallery there is a grid although I'm not sure how to control the width.
I don't see any choices in powerstore gallery setting, like in power gallery.
In the js for ribbon, I see
options: {
initial: 0,
perPage: 8
Is this where I'd be able to set it? If yes, what will cause a second row to appear?
Any advice most appreciated.
I just found some more choices in gallery area. I'll check those out...
You would have to use the grid. The ribbon always only shows one row and scrolls.
The grid you would just have to update the .css for the container. If you send me a link to the grid you are using I can find the correct line number in the css to update.
biz295654WebAssist
Thanks Ray. I found the tiny ribbon option just now. That will solve my problem. Thanks so much.
