API Key
index.php
The js and the div match up and I'm getting the error still. Any help would be great. The previous thread did not have any info pertinent to my case, thanks.
index.php
It looks like you have two script references with two different API keys. You can probably go into the header of the page and delete the one you aren't using and that should fix the problem.
Great it's working now. I deleted pone and got a new key for the other because the error was still there. ty
