PowerStore 4.5 Test Mode not working
Thread began 8/26/2011 12:02 pm by CheopisIV | Last modified 8/26/2011 12:11 pm by Jason Byrnes | 446 views | 1 replies |
CheopisIVBeta Tester
I thought it wouldn't matter anymore since I have everything live and running, but I found myself wanting to use the test mode again with a setting change in the Admin panel. The issue;
Even in test mode, the store sends me to Paypal following purchase if I have the Payment Gateway set to Paypal Standard. If I disable the payment gateway (set to 'None'), it then works and gives me the 'Store is in Test Mode' text after the order.
I had a fix from a WA member that seemed to work fine, but I recently found that it also disabled the entire referral to Paypal even with a live order out of test mode, so I just reupped the original script to make the store work again.
I'll attach the edited php page for you to see, I can test any new code changes and report the effect.
process_transaction(Edit).zip
In reality, there is no such thing as test mode when using PayPal standard.
Testing paypal standard is done using an IPN Tester environment. For test mode to work, you will need to use a differant gateway other than paypal standard.
