Log-In reset question...
Thread began 8/26/2011 8:52 am by daniel276949 | Last modified 8/31/2011 7:53 am by Jason Byrnes | 1831 views | 6 replies |
daniel276949Beta Tester
i am closing the photo album at the family.ryani.net and moving everthing over to a replacement domain, family.plushkin.net...
since we have an increasing number of last names for our family everyone thought i should move the album to the plushkin domain...
the server techs copied everthing over from the ryani to the plushkin and the website seems to work ok, however, that said i tried to log in the new replacement domain and i can't log it to be sure it is all working correctly...
how do reset the passwords and login information so i can log in the the admin panel?
the admin username and password are stored in the wa_settings table of the gallery database.
the first thing to check is that the server is properly configured to save session variables.
Use the session test page from the following thread:
showpost.php?p=23826&postcount=2
if the test fails, you will need to contact the host to have them fix the problem, it is most likely a bad session.save_path setting in the php.ini file.
i am unable to find the file ...
where would i find the file? Thank You
it is not a file, it is a table in the MySQL database used by the gallery.
you will need to access the database server directly using PHPMyAdmin or another MySQL GUI tool to see the database tables.
Thank You
Have a Great 2011
Daniel
upgrading from pg1 to pg2
Good Morning....
When can we get the PG2 working? do you have any idea what is wrong with the programming yet?
Thanks, Daniel
I have forwarded this to ray, he should be looking into this now.
