multiple file uploads
I am a bit lost with the syntax for multiple file uploads. I created the hidden field:
<input name="soundfile_edit_<?php echo $RepeatSelectionCounter_1; ?>" type="hidden"
class="text" id="soundfile_edit_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_rsDownloads['soundfile']; ?>" />
and the the file field:
<input type="file" name="soundfile_change_<?php echo $RepeatSelectionCounter_1; ?>" id="soundfile_change_<?php echo $RepeatSelectionCounter_1; ?>" />
further up the code from UE4 looks like:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../../dyn/mp3/",
'FileName' => "[FileName]",
'DefaultFileName' => "".((isset($_POST["soundfile_edit_".$RepeatSelectionCounter_1]))?$_POST["soundfile_edit_"].$RepeatSelectionCounter_1:"") ."",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Submit"])){
WA_DFP_UploadFiles("WA_UploadResult1", "soundfile_change_".$RepeatSelectionCounter_1 ."", "0", "", "false", $WA_UploadResult1_Params);
// WA DataAssist Multiple Updates
if (isset($_POST["Submit"])) // Trigger
$WA_loopedIDField = array("WADA_RepeatID_id");
$WA_connection = $myconnection;
$WA_table = "soundfiles";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "id";
$WA_fieldNamesStr = "titel|titel_en|soundfile";
$WA_columnTypesStr = "',none,''|',none,''|',none,''";
$WA_connectionDB = $database_myconnection;
$WA_multipleUpdateCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleUpdateCounter)) {
$WA_fieldValuesStr = "".WA_AB_getLoopedFieldValue("titelDE", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("titelEN", $WA_multipleUpdateCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("soundfile_edit", $WA_multipleUpdateCounter) ."";
$WA_where_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleUpdateCounter);
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
$WA_multipleUpdateCounter++;
if ($WA_redirectURL != "") {
But no file updates are made. The update I changed by hand to:
Any idea?
