Warning errors in Power Gallery Admin
Thread began 8/23/2011 11:28 am by amandacomer368110 | Last modified 8/23/2011 3:56 pm by Jason Byrnes | 4306 views | 3 replies |
amandacomer368110
I'm getting these errors at the top of my Power Gallery admin pages:
Warning: fopen(../admin_gallery/Connections/installed_gallery.txt) [function.fopen]: failed to open stream: No such file or directory in /data/22/1/12/150/1990802/user/2176385/htdocs/gallery/admin_gallery/images/installed.png on line 15
Warning: filesize() [function.filesize]: stat failed for ../admin_gallery/Connections/installed_gallery.txt in /data/22/1/12/150/1990802/user/2176385/htdocs/gallery/admin_gallery/images/installed.png on line 16
Warning: fread(): supplied argument is not a valid stream resource in /data/22/1/12/150/1990802/user/2176385/htdocs/gallery/admin_gallery/images/installed.png on line 16
Warning: fwrite(): supplied argument is not a valid stream resource in /data/22/1/12/150/1990802/user/2176385/htdocs/gallery/admin_gallery/images/installed.png on line 18
Warning: fclose(): supplied argument is not a valid stream resource in /data/22/1/12/150/1990802/user/2176385/htdocs/gallery/admin_gallery/images/installed.png on line 19
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /data/22/1/12/150/1990802/user/2176385/htdocs/gallery/admin_gallery/global.php on line 37
Any ideas? I haven't done anything special to modify things other than creating custom designs for the gallerys.
here is a new copy of the installed.png file to correct the problem, copy it to the following folder in your site:
also, edit the admin_gallery/global.php file, change lines 34 - 37:
require_once("images/installed.png");
//PowerGallery version
$wa_settings['pg_version'] = '1.2.0';
mysql_free_result($result);
installed.png.zip
amandacomer368110
That fixed the line 37 error, but I still get the errors below. Could it be that the installed.png file is corrupt? I can't open that file in any program that I have here.
Warning: fopen(Connections/installed_gallery.txt) [function.fopen]: failed to open stream: No such file or directory in /data/22/1/12/150/1990802/user/2176385/htdocs/gallery/admin_gallery/images/installed.png on line 15
Warning: filesize() [function.filesize]: stat failed for Connections/installed_gallery.txt in /data/22/1/12/150/1990802/user/2176385/htdocs/gallery/admin_gallery/images/installed.png on line 16
