Dreamweaver Error Message
Thread began 8/23/2011 7:58 am by Martin | Last modified 8/23/2011 9:55 am by Martin | 827 views | 2 replies |
Martin
Greetings,
I am trying to use power CMS builder to edit Power CMS content from the properties bar in DW.
I am selecting "edit in PowerCMS" and I get the following error message - "could not find admin on site - browse to the page through the CMS admin to edit content".
All I have created is a default install of Power CMS with the directories that it has defined. Any idea on how to fix this or what causes this as this was one of the reasons I purchased the program to directly edit CMS content from within Dreamweaver.
Thanks!
Martin
Martin
just a quick update, if I select the other option to "edit in dreamweaver". It creates a temp file that I can update and it does upload it to the database. However, it leaves behind a temporary PHP file called PCMS_Edit_ContentID_1_Temp.php.
Shouldn't this file delete itself when done?
Thanks,
Martin
Martin
I think I solved this issue. When I restarted Dreamweaver, I opened the files again, went through the process of updating a page. The temp file was created and when I went "Save All" the temp page closed and deleted itself.
Dreamweaver issue??
Thanks again thought!
