eCart session variables
Thread began 8/22/2011 11:18 pm by david331670 | Last modified 8/25/2011 7:27 am by Jason Byrnes | 2252 views | 6 replies |
david331670
I Just cant get it.
I am starting to produce photobooks.
My books assembly software loaded onto users computer assembles the files to a folder, the finished files are sent to my FTP site and the user logs onto my cart page with link address similar to this: http://localhost:/Shop-Photobooks.php?pgx=32&pid=274&job_id=Cards_475"
I can "Get" the data for the number of pages, (pgx=32) calculated from page price in data base, the product ID (pid=274) from product ID in data base, and I can display the Job_id number ( Cards_475). These item display and calculate properly. I want the job_id to be carried forward and displayed on the cart summary page, the confirm page and the cart success page. This JobID is related to the folder on my FTP site and it is important to have the job_id displayed on the success page/invoice as this is the way the customer can have reference to his job.
I can display the job_id number if I include it in the URL but I cannot get it to carry over to any or all three pages.
I just know it is simple but no luck.
I have used this code to display URL items on the cart page.
Line11 after:
$Spectrum_online->GetContent();
session_start();
// store session data
$_SESSION['PBksID']=$_GET['job_id'];
body
html
This in a table cell:
//retrieve session data
echo "Job identification=". $_SESSION['PBksID'];
can you point me in the correct direction please.
David
change this line:
if(isset($_GET['job_id'])) $_SESSION['PBksID']=$_GET['job_id'];
this way the session will only get set if the job_id querysting variable exists.
My bet is that the session is getting reset at some point to be empty, and that is why it is not carrying over to the other pages.
once it is set, you should be able to use:
on any page to display the session value.
david331670
Thanks for that.
I found the problem and the job_id now displays on the cart summary page. However I now cant get it to display on the confirm page and success page.
Link from cart summary to secure site for transaction.
All the rest of the data works ok to confirm and success pages, just the job_id is the headache. I keep trying to put hidden data at the bottom of the car summary "
<input type="hidden" name="PagePrice_<?php echo $Spectrum_online_Index; ?>" id="PagePrice_<?php echo $Spectrum_online_Index; ?>" value="<?php echo $Spectrum_online->DisplayInfo("PagePrice") ?>" />
The above portion works.
Below is my attempt at a hidden field that is not connected to the data base.
Its pure rubbish but , Am I on the right track
<input name="job_id" type="hidden" value="<?php echo $job_id ;?>"/>
Thanks again
the code for the hidden element would be:
<input name="job_id" type="hidden" value="<?php echo $_SESSION['PBksID'];?>"/>
then on the checkout page, use the following code to reset the session on the secure server:
<?php if(isset($_POST['job_id'])) $_SESSION['PBksID']=$_POST['job_id']; ?>
david331670
What a star you are!!
Finally got it working.
I have used the following code to reset the session on the secure server:
I have put this code at the bottom of the checkout page:
</body>
</html>
Is that correct? or somewhere else?
Many thanks
David
david331670
Cart error
Me again
When I use the cart for the photobooks for eg "?pgx=32&pid=274&job_id=Cards_475" as described above all now works well
However when the item is not in the cart, ie different item I get an error message "Cart-A.php" on line 238" which is line 238= " <?php echo "Job ID: ". $_SESSION['PBksID']; ?>"
Do I use something like this in front of the code "if(isset($_GET['job_id'])) " so that I dont get an error if the code is not there.
I have this at the top of the cart summary page: <?php
David
you dont mention what the error message says.
you only mention the code that is creating the error.
this only gives me half of the story
I have no way of knowing how to fix an error without knowing what the error is.
