Fatal error: Maximum function nesting level of '100' reached
Thread began 8/22/2011 10:33 pm by karen.marley367377 | Last modified 8/23/2011 8:23 am by Jason Byrnes | 1893 views | 5 replies |
karen.marley367377
I am testing the themes function in FB. Have downloaded the lasted versions, 101, downloaded the fix, clear cache, etc.
Am getting this error:
Fatal error: Maximum function nesting level of '100' reached, when testing on local servier, which is wampserver. The error refers to this file:
webassist\framework\framework.php on line 36
the code is:
require_once( "webassist/framework/library.php" );
require_once( "webassist/framework/framework.php" );
if("" == ""){
$WA_theme_1314077095497_Content_Empty = "";
$WA_theme_1314077095497_Content = new WA_Include(__FILE__);
$WA_theme_1314077095497_Template = new WA_Include("Templates{$WA_theme_1314077095497_Content_Empty}/theme.php");
require($WA_theme_1314077095497_Template->BaseName);
$WA_theme_1314077095497_Template->Initialize(true);
?><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html><!-- InstanceBegin template="/Templates/Themes/testone_fw_theme.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<!-- InstanceBeginEditable name="doctitle" --><!-- InstanceEndEditable -->
<!-- InstanceBeginEditable name="head" --><!-- InstanceEndEditable -->
</head>
<body>
<!-- InstanceBeginEditable name="content" --><!-- InstanceEndEditable -->
</body>
<!-- InstanceEnd --></html>
if(isset($WA_theme_1314077095497_Template)){
$WA_theme_1314077095497_Content->Initialize();
$WA_theme_1314077095497_Template->ReplaceTemplateRegions($WA_theme_1314077095497_Content);
print($WA_theme_1314077095497_Template->Content);
karen.marley367377
framework.php file
Attached is the offending file.
framework.zip
karen.marley367377
framework file and theme
Originally Said By: karen.marley367377
Here is the framework file and theme.
Regards
frameworkandtheme.zip
in the newtheme.php file, try changing line 9:
$WA_newtheme_1314098087212_Template = new WA_Include("../../Templates{$WA_newtheme_1314098087212_Content_Empty}/newtheme.php");
$WA_newtheme_1314098087212_Template = new WA_Include("../../Templates{$WA_newtheme_1314098087212_Content_Empty}/newtheme.dwt.php");
karen.marley367377
Change as suggested causes this:
Now get :
Notice: Undefined variable: WA_newtheme_1314098087212_Content_Empty in E:\_WebServer\_proudly-Aug-2011\Templates\Themes\newtheme.php on line 9
Call Stack
# Time Memory Function Location
1 0.0004 681408 {main}( ) ..\newtheme.php:0
( ! ) Notice: Undefined variable: WA_newtheme_1314097601286_Template in E:\_WebServer\_proudly-Aug-2011\Templates\Themes\newtheme.php on line 10
Call Stack
( ! ) Notice: Trying to get property of non-object in E:\_WebServer\_proudly-Aug-2011\Templates\Themes\newtheme.php on line 10
Call Stack
( ! ) Warning: require() [function.require]: Filename cannot be empty in E:\_WebServer\_proudly-Aug-2011\Templates\Themes\newtheme.php on line 10
Call Stack
( ! ) Fatal error: require() [function.require]: Failed opening required '' (include_path='.;C:\php\pear') in E:\_WebServer\_proudly-Aug-2011\Templates\Themes\newtheme.php on line 10
Call Stack
