Server Behaviors "! (Prior Version)
Thread begun 8/22/2011 3:23 am by Nature Photographer | Last modified 8/22/2011 2:24 pm by Nature Photographer | 2792 views | 2 replies |
Nature Photographer
I have had the User Registration Solution Pack since it was first released and it has worked fine with little drama. I recently decided to redo my website and upgraded to the latest version of Security Assist 2.0.2 plus I have other extensions that do Validation.
Now when I include the URSP I notice in the Server Behaviors panel "! *** (prior version)" relating to Security assist behaviors found in the solution Pack.
I'm using DW CS5.5 with the latest extensions from Webassist and want to know whether they are compatiable and how to fix this.
Thanks in advance
John LangerBeta Tester
All this is telling you is that the solution pack is using a prior version of SS in relation to the one you have installed. It will work just the same as always and no action on your part is needed.
However if you do wish to upgrade the version of SS used just double click on the behaviour and then click OK. This will update the code and (probably) create new files that you'll need to upload to the server (most likely in the webassist folder).
Personally, I wouldn't bother but it's up to you.
Nature Photographer
Thanks John
