fixed error mesage location
Thread began 8/21/2011 5:17 pm by software.current355386 | Last modified 8/23/2011 6:01 pm by software.current355386 | 1182 views | 2 replies |
is it possible to have validation errors sow in fixed area expecailly when sptyvalidationtool tips added t form generated, the std one shows below box shift up if error , this i finf irratating
if cnt be done now possible enhanement
how about hints, apppering on tering field, tell user what they are expected to typein.
how about reset button - clear fields an sessin varibles?? so can start again
the Validation Tooltips for Spry extension will convert spry validation errors to tooltip windows to prevent the error shifting the form element on the page:
To add hints to your page, you can add a spry tooltip, go to Insert -> Spry Tooltip
you can add a reset button t the form by going to insert -> Form Button. select the newly added button in design view, then go to the property inspector and set the Action to reset Form.
thanks for reply, got it all working now, not 100% with it.
woul like to have dedicated ms area on form/screen so it doesnt spoil the esthetis so tthe user gets to know were msgs will appear.
future enhancement ??
need ro find css coding s i can tweek it to my likng
