Delete User
Thread began 8/20/2011 5:24 am by daniel387105 | Last modified 9/02/2011 8:18 am by Jason Byrnes | 3622 views | 17 replies |
daniel387105
Error DataAssist
i have already set this up but i get this error when i delete the user and it shows at the very top of my website???? i click on delete and i get this and this is correct but on this page i get the bellow error????
Delete User
Delete Record
Are you sure you want to delete the following record?
UserID:
36
UserEmail:
test.@test.com
This bit show live on my website when i try to delete the user the delete usre works but i need to sort this error as it looks bad????
Warning: Cannot modify header information - headers already sent by (output started at /home/justvibe/public_html/users_Delete.php:14) in /home/justvibe/public_html/users_Delete.php on line 88
this is the most common error in PHP.
it means that there is out put on the page at line 14 or 13 of the users_Delete.php page.
see the following thread for details on the cause, and how to fix it:
showthread.php?t=19285
daniel387105
line 13 <link href="css/navigation-style.css" rel="stylesheet" type="text/css" />
line 14 <link href="css/style.css" rel="stylesheet" type="text/css" />
the error is saying that there is HTML on the page before the session)start() or header functions are called.
the css code should be just before the closing </head> tag in your document, having it up around line 13 and 14 is to soon.
daniel387105
Line 13 <link href="css/navigation-style.css" rel="stylesheet" type="text/css" />
yes, that code at line 13 and 14 is causing the error, see my previous reply
daniel387105
HI ok i have moved the css to just before the </head> and i get this message
Warning: Cannot modify header information - headers already sent by (output started at /home/wwwjust/public_html/users_Delete.php:13) in /home/wwwjust/public_html/users_Delete.php on line 86
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("admin")){
WA_Auth_RestrictAccess("access-denied.php");
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<head>
<title>Authorised Access Delete User Just Vibe Family Only</title>
<meta name="Keywords" content="online radio, internet radio, online internet radio station, funky house, garage radio, urban radio, uk garage music, UK internet radio webcam, electro radio, funky house radio, webradio" />
<meta name="Description" content="Just Vibe Online Radio features Live djs playing 24/7.djs playing uk garage, drum n bass, electro house, funky house, urban, trance, old skool" />
<?php require_once('Connections/myconnection.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$ParamUserID_WADAusers = "-1";
if (isset($_GET['UserID'])) {
$ParamUserID_WADAusers = (get_magic_quotes_gpc()) ? $_GET['UserID'] : addslashes($_GET['UserID']);
mysql_select_db($database_myconnection, $myconnection);
$query_WADAusers = sprintf("SELECT UserID, UserEmail FROM users WHERE UserID = %s", GetSQLValueString($ParamUserID_WADAusers, "int"));
$WADAusers = mysql_query($query_WADAusers, $myconnection) or die(mysql_error());
$row_WADAusers = mysql_fetch_assoc($WADAusers);
$totalRows_WADAusers = mysql_num_rows($WADAusers);?>
// WA Application Builder Delete
if (isset($_POST["Delete_x"])) // Trigger
$WA_connection = $myconnection;
$WA_table = "users";
$WA_redirectURL = "users_Results.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "UserID";
$WA_columnTypesStr = "none,none,NULL";
$WA_fieldValuesStr = "".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
$WA_comparisonStr = "=";
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_myconnection;
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
if ($WA_redirectURL != "") {
header("Location:".$WA_redirectURL);
</head>
<head>
&lt;/head&gt;
&lt;body&gt;
&lt;div id="shadow="shadow">
</head>
<body>
All of the html that appears in the php code should be moved below the php code... so this portion:
<head>
Should be moved to just above the first <link> reference.
It also appears you have an extra "<head>" tag above the body that should be removed.
If you continue to have problems, please attach a zipped copy of the page rather than copy and pasting it so that we can correct and send back the updates.
daniel387105
Ok still something not right now when i hit the delete btn it just gos to a blank page with this message
Not Found
The requested URL /home/wwwjust/public_html/users_Results.php was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.13 (Unix) mod_ssl/2.2.13 OpenSSL/0.9.8e-fips-rhel5 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 Server at www.justvibe.co.uk Port 80
users_Delete.zip
there is a fix for this issue in the known issues section of the Data Assist download center page.
