IE6 issues with menu
I created this menu with CSS menu writer 2.0.5. The problem is in IE6 it displays the background of the text in the menu in a different color. Works fine in other browsers.
index.htm
Any ideas anyone??
index.htm
Any ideas anyone??
looks like you changed the background color in the menu css manully by editing the code, you will need to make the same changes to the CSSMenuWriter/cssmw/menu_ie.css and CSSMenuWriter/cssmw0/menu_ie.css file as well.
Awesome. thanks for pointing me in the right direction. much appreciated.
