sitemap.html not really formatted
Thread begun 8/18/2011 2:04 am by david428573 | Last modified 8/19/2011 6:41 pm by david428573 | 4011 views | 4 replies |
david428573
Although level-n classes are defined and pages are in a hierarchy, the sitemap.html file is a single-level flat list, with the list items like this:
mysubject
mysubject/subtopic
mysubject/anothersubtopic
mysubject/anothersubtopic/thirdleveltopic
yoursubject
yoursubject/subone
etc.
Wouldn't it be more sensible to insert the appropriate <ul> tags to introduce a new subtopic, and at least limit the text to the basename? Even better would be to pull the text from the target page, from a user-configurable tag like <title> (most obviously), or the first <h1> on the page, or SOMETHING.
As it is, the site map may be useful in its XML form for search engine submission, but I can't have the HTML version on my site, it looks like ... well, what it is. Auto-generated without regard for style or usability.
Am I just completely missing the secret config options for this program?
In the site map wizard, under the Header, there are controls to move an item left or right.
moving an item to the right will create a new sub list, moving it to the left will remove it from a sublist.
at the bottom, in the label section, it will use the page name, you can edit this to use another label if you like.
david428573
Off to see the wizard..
Um - what wizard? Here's what I'm doing:
Site -- Webassist Site Tools
Select Surveyor and click GO
I now have these choices:
[] Create from site
[] Exit existing site map
[] Select pages manually
I choose "create from site", and my options are:
Web Address
Save site map at
Page file types
Links to follow
Maximum pages
Follow dynamic links
Ignore URL parameters
Edit site map when done
When it's done I get a list of each page and these are the options:
+ add - delete Y cut
Pages:
URL:
Last Modified:
Change Frequency:
Priority:
[ HELP ] [ FINISH ] [ CANCEL ]
That's it. There is no "under Header", no controls to move an item left or right, no label section.
I would tell you the version but the software does not display it. I just purchased this 3 weeks ago.
to create the HTML Site map, go to Insert -> Webassist -> Surveyor _> HTML Site map,
This is the wizard I am referring to.
david428573
Here's how to do this
I've attached a Perl program that does what I expected this commercial product to do - intelligently indent the items to reflect the filesystem hierarchy, and pull the text from the Title tag. This is 20 minute's work. Yipe.
