Contribute Paypal Buttons
Is there an option to add another currency to the button creation wizard. We want NZ$ and it is not a currency option offered. This is with Contribute CS5.
Thank, David
Thank, David
in the code for the paypal button, there should be a hidden element named "currency_code"
<input type="hidden" name="currency_code" id="currency_code" value="USD" />
you can change the value of this hidden element to change the currency, see the following page for a list of currency codes excepted by paypal:
e_howto_api_nvp_currency_codes
Thanks for this info.
Not sure it will help them as there are many items for sale and one of the benefits of using the wizards in Contribute is the ability to add the add to cart buttons with minimum fuss.
If they had dreamweaver it might be different.
Is there an ability to add a currency to the list offered by the Wizard in Contribute - even a registry entry or config file that could be modified perhaps?
Thanks again, David
no, this cannot be added to the wizard.
