checkout wizard with a template
OK I ran without a template and it worked I run it with a template and get this
Parse error: syntax error, unexpected '?' in C:\xampp\htdocs\INSTR\confirm.php on line 33
Here is my confirm.php....?
I am running the a template with the checkout and keep getting the previous mentioned result
this error is coming from the email code.
what version of form builder do you have installed?
make sure you have the CSS Form Builder 2.0.1 - Support Release 2 available from the download center installed before running the checkout wizard.
if you have a previous version installed, you will need to uninstall it form the extension manager before installing this newer one.
