Surveyor Error Submitting Site Map
Thread begun 8/16/2011 11:32 am by cmanassa421024 | Last modified 8/17/2011 9:23 am by Jason Byrnes | 2425 views | 1 replies |
cmanassa421024
Created sitemap.xml and sitemap.html. Submit sitemap step and select the site from the drop down and select the sitemap.xml from the folder list. Have put and all browsers checked. Upon hitting OK, get an error = Please select a valid URL to your XML site map.
Double check the HTTP Address you have specified in the Dreamweaver Site Settings on the local info tab, this address will need to properly point to your site online, this address is used when submitting the site map to the search engine to tell it where to find the site map xml file.
