Using worldpay questions
Thread began 8/16/2011 6:22 am by Base5 Designs | Last modified 8/17/2011 7:00 am by Jason Byrnes | 1081 views | 3 replies |
Base5 Designs
Hi there,
I am using worldpay as the payment provider.
I have run the checkout wizard and my pages have been created.
in the merchant contol panel for worlpay, i am unsure as to what page to set up for the payment response url?
i gather that it can take up to 4 days fro the payment to be processed, in paypal it has the IPN feature, does worldpay have something similar, i would like to store the order in the database (which i have used the default setup from the ecart wizard 2 tables order and orderdetails) when the payment is recieved i would like to have a payment recieved column set to true once the payment has been recieved.
how does worldpay determine wether to go to checkout sucsess page or checkout fail page? as i can only put 1 url in the checkout response on the worlpay merchant control panel.
or do i need to create a page to process the repsonse that redirects to the appropiuate page depending on the response?
and if so how would i go about doing it?
ive looked on the help for the extension but there does not seem to be any guides for specific gateways other than paypal and sagepay/protx
thank in advance for advice/help
you need to configure the payment response page.
The World Pay will send the payment response data through the querystring:
payment_response.html
see the Parameter Description page for the names of the parameters included in the payment response.
you can get the values from the payment response using the GET global:
<?php echo($_GET['perameterName']); ?>
the payment response is the worldpay equivalent to paypals IPN
Base5 Designs
Thanks for your reply jason, i am assuming i have to create the payment response page from scratch, as i dont see any page created by the wizard.
yes, that is correct, you need to create the payment response page.
