Where is datepicker?
Thread began 8/15/2011 3:04 pm by nickj | Last modified 8/16/2011 11:52 am by Jason Byrnes | 963 views | 5 replies |
nickj
I understand I should not use form toolkit as it conflicts with css form builder 2. Where do get datepicker to add to an existing form?
Nick
to add a Date Picker in CSS Form builder, you will need to click the edit button next to the form type selection to edit the form contents.
in the form contents edit screen, click the plus button to add a new fieldset, select the Group, then set the category to Form Elements and Select Date Picker for the type.
nickj
My mistake. How do I add date picker to an existing form which was not built with cssform builder?
Form tool kit put a link in the web assist menu for adding date picker to any form.
Thanks Nick
You cannot do this with CSS Form Builder, you need to use Form Toolkit.
CSS Form Builder is for building CSS Forms.
Form Toolkit is for Modifying existing forms.
nickj
My understanding was that there was a conflict with cssform builder and form toolkit.
Nick
no, there is not a conflict with Form Toolkit and CSS Form Builder, just make sure you are using the CSS Form Builder Support release from the download center.
