Standalone browser showing index view and file browse broken link.
Thread began 8/15/2011 4:06 am by neo314 | Last modified 8/17/2011 9:06 pm by neo314 | 899 views | 3 replies |
I found that the standalone file browser needs to open index.php specifically.
While my live server defaults to index.html, index.php, etc. My testing server does not and the stand alone file browser was opening an index view of the webassist/kfm directory.
I solved it by adding an .htaccess file to the directory.
I also found that the select_none.png file was coming up as a broken link. Changing the line in filebrowse.js from:
newImg.src = 'webassist/kfm/themes/webassist_v2/icons/select_none.png';
newImg.src = '/webassist/kfm/themes/webassist_v2/icons/select_none.png';
solved that.
P.S. I also just realized the stand alone browser inserted the input element as:
<input type="text" value="" id="myfile" name="myfile" readonly style="float:left;"/>
I believe it should be:
<input type="text" value="" id="myfile" name="myfile" readonly style="float:left;" />
with the extra space before the />
In working with Dani Chankhour from support today, the fix to this problem is in webassist/kfm/filebrowser.js
Change line 91 from:
var kfm_url="webassist/kfm/?theme=webassist_v2";
var kfm_url="webassist/kfm/index.php?theme=webassist_v2";
This issue will show up on any server that allows index views. Also the fix that I posted for the 404 error on the select_none.png file will not work if your web site is in a subdirectory.
