protecting php formating
How can I insert php tags into data base with out it being reformated using html editor?
storing PHP code in the database will not be executed by the PHP engine when the page is created at run time.
This will not work as intended.
Is there a way to convert my stored data base value to <?php echo at run time.
No, you cannot store php code in the database and have the php engine parse it at run time.
