UE, no email sent out?
Thread began 8/13/2011 2:46 am by anmartinez428906 | Last modified 8/17/2011 10:01 am by Jason Byrnes | 1092 views | 5 replies |
anmartinez428906
Hello,
I am having issues receiving my email from UE. I've changed the "To" email address to other emails I have and I still do not receive anything. I have attached my PHP script, hopefully someone can provide some guidance. Thanks.
Tony M.
specformsubmission.php.zip
are you being redirected to the thankyou.html page?
What have you set the from email address to? make sure this is a valid email address for your domain
On the SMTP Server settings tab (click the envelope icon) what have you set the smtp server and port to? double check with your host that you are using the correct smtp server.
Who is your host? you may need to check the option to "include from address as an additional parameter".
anmartinez428906
Yes i am be redirect to my thank you page.
The from email address is a dynamic text field I set.
I have not set an SMTP Server settings, I've let those setting unchanged. (Should I fill those setting in?)
My Host is www.000webhost.com.
some host will not relay the email address if the from address is not a valid address for your domain.
set the from address to a valid address from your domain.
you can set the reply to address to use the dynamic value from your form.
in most cases, leaving the smtp server blank is ok but you will need to check with your host if it is not working to determine the correct smtp server to use for sending an email through the php mail() function.
if it is all configured correctly, and the email is still not being sent, it is a problem at the SMTP server end, for some reason the SMTP server is not relaying the email to the recipient. to determine why, you will need to contact the host to have them look into the smtp servers error logs.
anmartinez428906
I redid my forms from scratch and deleted any php files I had uploaded on my server and to my surprise my forms are working as expected, I am getting emails with attachments sent to the different email addresses I have specified. I appreciate your attention and help. Thanks.
glad to hear it is working.
