Show region for specific user?
I'm looking for a way to show a region if a specific user (i.e., the administrator) is viewing the page. Is there some session variable similar to MM_Username I can check for?
Thanks - Joe
Thanks - Joe
the users ID is stored in a session when they login by default, you could use that session variable.
to find the session variable name, double click the authenticate user behavior on the login page and go to the third step, this will list the names of the sessions being set on login.
