I redid checkout to not use a gateway
This is what I got.....
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'York City,24.77,1)' at line 1
when I checked out it wrote a orders header but no detail
please send a copy of the confirm page in a zip archive so i can see the code.
this was an issue with the data types specified for the options columns in the order details table.
the data types was set to int, we changed it to varchar.
