Problem with the Designs on PowerStore
Thread began 8/10/2011 8:31 am by tvindett429158 | Last modified 8/10/2011 9:16 am by tvindett429158 | 844 views | 2 replies |
tvindett429158
At first everything worked fine.
I messed around learning how the edit design templates worked. Then all of a sudden I get this error:
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: No such file or directory in /home/content/51/8112451/html/beta/webassist/plugins/styler/styler.php on line 99
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in /home/content/51/8112451/html/beta/webassist/plugins/styler/styler.php on line 100
Warning: fread(): supplied argument is not a valid stream resource in /home/content/51/8112451/html/beta/webassist/plugins/styler/styler.php on line 100
Warning: fclose(): supplied argument is not a valid stream resource in /home/content/51/8112451/html/beta/webassist/plugins/styler/styler.php on line 101
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in /home/content/51/8112451/html/beta/webassist/plugins/styler/styler.php on line 104
Fatal error: Call to a member function asXML() on a non-object in /home/content/51/8112451/html/beta/webassist/plugins/styler/styler.php on line 117
I have tried re uploading some files, but that hasn't corrected anything.
try deleting the themes/temp_editing/ folder form the server, it will be recreated when you try to edit a theme the next time.
tvindett429158
Thank you, that did it. I truly appreciate the timely response.
