Getting started with ecart
Thread began 8/08/2011 6:42 am by sjuno299871 | Last modified 8/08/2011 9:37 am by Jason Byrnes | 848 views | 2 replies |
sjuno299871
I have 9 shirts each on a diferent page 9 pages. All is want to do is to. Select a size, a color and a charter name then add to cart
I have a page for each shirt, each shirt has a different number of colors I would like them to pick from (select list). Then pick a charter name (55 choices from a selct list)Then pick a size - Sizing choice XS-4XL(select list). .
I have a price for each shirt that needs to be adjusted if they choose a 2XL add $2.00, 3XL add $4.00 4XL add $6.00. They also have a choise of size XS-4XL. but I will do that later as I just want this to be functionally
I am doing a static add to cart button for each page
In the bindings put in a product ID, description, weight, price and 3 select lists to be updatable. Then I list my select values in the select list values.
On page 5 of the e cart getting started guide it says if you buttons are static I may need to modify at some time ie price then says to go to Window > Server Behaviors and double click on ecart add from recordset I do not see that one ....so went on....
I am just working on one of the nine pages added two things can view them im my cart..
but when I go to do the check out thru Sandbox I get
Fatal error: Call to undefined function curl_init() in C:\xampp\htdocs\NOBS\WA_eCart\Adv_CO_Scripts\PP_DirectPayment_PHP.php on line 311
error
sjuno299871
Support call
For $99.00 would I be shown how to set up one cart page and then process it thru to final checkout.
for the error message, you need to enable cURL in the php.ini file:
enable-curl-with-xampp-on-windows-xp.html
yes, we could walk you through this in premiere ticket appointment.
