Used CSS Button Styler on Cart Page
Thread begun 8/05/2011 8:36 pm by johna1964 | Last modified 8/08/2011 12:09 pm by Jason Byrnes | 3540 views | 4 replies |
johna1964
I thought I'd check this out on a test site before using it on the real thing. (Vista and DWCS4)
The button switched out easily:
In split view, I selected the buttons individually (made sure the code was hightlighted), used the external style sheet option. Created the desired preset. Hit okay.
Dreamweaver's Input Tag Accessibility Attributes dialog box pops up. I entered the same ID (as the former button) into the ID text field.
All the buttons switched out perform correctly.
The external css is easily modifiable. (The button styles are the only thing on the page)
One issue I'm having is the font size will not change either by preset or by css. It created the font size extra small even regardless of px size.
Other than this (I'm sure there is a solution somewhere) I am super pleased with the performance of CSS Button Styler...
Anyone else with this issue?
Appending to this post:
When I replaced the contact form button (with no problem) I could not reenter form builder to modify the form. Had to use the css page....anyone try yet...or have similar experience?
johna1964
please send a link where i can see the probelm to investigate the cause.
can you provide more details on this problem:
what happens when you try to reenter the wizard, does it give an error message?
johna1964
Jason,
When I tried to reenter via the turquoise tab, there was absolutely no response....the properties inspector would not pull up the reentry point....I tried on several occasions.
I've been working the form to change the way the universal email mails and decided to recreate the form again...
If the issue persists, or not, I will post and let you know.
johna1964
Jason,
When I recreated the form...added the CSS Button Styler...reentry was perfect. I have no idea why it didn't work before.
I would think it was because something was wrong with the way I modified the the form css....before the button styler was even an option...
Also; the font size problem was solved...
it's an awesome extension.
Thank You!!
johna
ok, glad to hear it is working.
